Matt,
The problem with your solution is that if I explode the grading objects, and
just use the feature lines for the FG surface, I have to create many
surfaces, as I don't want the little groups of grading areas, to create one
large surface where it grades outside of the daylight lines between the
basins, channels etc.
Also, the grading groups are dynamic, which is what appeals to me about
Civil 3d. However, if I cannot get the grading objects to be stable, and
work the way they should, I will eventually be forced to look for a
different software package that can handle this task (thinly veiled threat
to AutoDesk!).
Problems I am having:
After creating a grading object it seems to work O.K., but when I close and
re-open the drawing, half of the grading objects are missing or exploded
polylines (typically for daylight portion).
Sometimes, I just cannot create a slope or whatever, even though it should
by all accounts.
Also, the infill on my basins gets removed sometimes.
As I said before, when it works right, I jump up and down and want to kiss
myself (kinda like James Brown).
I just hope that the grading will become more stable VERY SOON!
Also I should note that I have all the latest updates, have a very good
computer and graphics card (Autodesk certified), and start my drawings based
on the latest template provided by Autodesk.
Alan B
wrote in message news:5804997@discussion.autodesk.com...
I dont know if this will help or not Alan, but I have had good success
creating my grading objects in a 2nd drawing. Then i would copy the feature
lines out of the grading drawing and paste them into the base drawing, and
add them to my FG surface. I have only done this when I cant get grading
objects to perform correctly in the base drawing. But typically I dont like
to use the grading objects if i can get away without them.
Out of curiosity, what types of problems are you having?
Matt
Adams and Clark
