AutoCAD Civil 3D General Discussion
Active Contributor
MapleWalnutIceCream
Message 1 of 10 (341 Views)
Grading not working around corners
341 Views, 9 Replies
02-26-2009 06:12 AM
I have a parking lot and I am using gradings to make the surface. I noticed that around some of the corners it doesn't follow the feature line curve. Any ideas? I have included a picture. The curve on the left works and the one on the right not.
*wfb
Message 2 of 10 (341 Views)
Re: Grading not working around corners
02-26-2009 07:19 AM in reply to: MapleWalnutIceCream
It does not follow curves.  It attaches to
nodes.  Select your curves and notice that there is a node where you have
existing triangles. Just add extra nodes with the included
tools.
Bill
I
the right not.
Active Contributor
MapleWalnutIceCream
Message 3 of 10 (341 Views)
02-26-2009 07:29 AM in reply to: MapleWalnutIceCream
Thanks. I found that exploding the feature lines into 3dpolys and then remaking them into feature lines also works ok, but not as smooth.
Active Contributor
MapleWalnutIceCream
Message 4 of 10 (341 Views)
02-26-2009 07:30 AM in reply to: MapleWalnutIceCream
*wfb
Message 5 of 10 (341 Views)
02-26-2009 08:50 AM in reply to: MapleWalnutIceCream
Feature lines can be curves but polys cannot.
Use the correct tools for the job and add nodes with the FL tools.
Bill
Thanks.
Employee
Matt.Anderson
Message 6 of 10 (341 Views)
02-26-2009 10:09 AM in reply to: MapleWalnutIceCream
How are you adding the information to the surface? Check your mid-ordinate distance...and make it SMALL.
Matthew Anderson, PE
Product Manager
Active Contributor
MapleWalnutIceCream
Message 7 of 10 (341 Views)
02-26-2009 10:41 AM in reply to: MapleWalnutIceCream
I didn't add the feature lines to the surface as breaklines. Your right to make that small.
I made gradings and set them to automatically produce a surface from them. I set their tesselation distance to 1. It seems to work sometimes. Some of my feature lines where broken at the PC which may have led to this problem. Joining them didn't seem to fix all of them.
I shouldn't need to add nodes to the curve of a feature line Bill. That is what the tesselation setting is for. But it probably is a good work around.
*wfb
Message 8 of 10 (341 Views)
02-26-2009 11:03 AM in reply to: MapleWalnutIceCream
One last question.  Have you tried to use
Feature Lines and their tools and use them as breaklines?  Doing items like
in your supplied .png would be a snap without using grading.
BTW, I'll take a double dip cone.
Bill
I
that small. I made gradings and set them to automatically produce a surface
problem. Joining them didn't seem to fix all of them. I shouldn't need to add
around.
Distinguished Contributor
C3D_RickGraham
Message 9 of 10 (341 Views)
02-26-2009 12:20 PM in reply to: MapleWalnutIceCream
Yeah, we make our mid-ordinate 0.01. It follows obediently around curves (for the most part).
Rick
Rick
coauthor Mastering Civil 3D 2012
I blog at http://simplycivil3d.wordpress.com
Employee
Matt.Anderson
Message 10 of 10 (341 Views)
02-27-2009 06:45 AM in reply to: MapleWalnutIceCream
Joining shouldn't make a difference difference only in that the grading object should only calculate once at that location, instead of twice (end of one featureline, beginning of the other)
The lack of data on the curve is control by the tessellation and mid-ordinate distances...
Product Manager
Announcements
Need installation help?
