Civil 3D Forum
Grading not working around corners
9 REPLIES 9
Message 1 of 10
MapleWalnutIceCream
1062 Views, 9 Replies
I have a parking lot and I am using gradings to make the surface. I noticed that around some of the corners it doesn't follow the feature line curve. Any ideas? I have included a picture. The curve on the left works and the one on the right not.
9 REPLIES 9
Message 2 of 10
in reply to: MapleWalnutIceCream
It does not follow curves.  It attaches to
nodes.  Select your curves and notice that there is a node where you have
existing triangles. Just add extra nodes with the included
tools.
Bill
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
the right not.
Message 3 of 10
Thanks. I found that exploding the feature lines into 3dpolys and then remaking them into feature lines also works ok, but not as smooth.
Message 4 of 10
Message 5 of 10
Feature lines can be curves but polys cannot.
Use the correct tools for the job and add nodes with the FL tools.
Bill
Thanks.
Message 6 of 10
How are you adding the information to the surface? Check your mid-ordinate distance...and make it SMALL.
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
Message 7 of 10
I didn't add the feature lines to the surface as breaklines. Your right to make that small.
I made gradings and set them to automatically produce a surface from them. I set their tesselation distance to 1. It seems to work sometimes. Some of my feature lines where broken at the PC which may have led to this problem. Joining them didn't seem to fix all of them.
I shouldn't need to add nodes to the curve of a feature line Bill. That is what the tesselation setting is for. But it probably is a good work around.
Message 8 of 10
One last question.  Have you tried to use
Feature Lines and their tools and use them as breaklines?  Doing items like
in your supplied .png would be a snap without using grading.
BTW, I'll take a double dip cone.
Bill
I
that small. I made gradings and set them to automatically produce a surface
problem. Joining them didn't seem to fix all of them. I shouldn't need to add
around.
Message 9 of 10
Yeah, we make our mid-ordinate 0.01. It follows obediently around curves (for the most part).
Rick
Message 10 of 10
Joining shouldn't make a difference difference only in that the grading object should only calculate once at that location, instead of twice (end of one featureline, beginning of the other)
The lack of data on the curve is control by the tessellation and mid-ordinate distances...
Product Manager
Autodesk (Innovyze)
Rail Community
