Civil 3D Forum
Grading Layout tools target value
5 REPLIES 5
279 Views, 5 Replies
How to change in " Grading Layout tools " The target value ? Distance to Surface Thx
5 REPLIES 5
nzeeben
You will need to alter the grading criteria, under the settings tab in the toolspace, expanding grading, then expand criteria sets. Under standard sets you will find the standard criteria you are using. You can then right click and choose edit.
Is locked. I can´t move it. "nzeeben" escribió en el mensaje news:11195216.1104855768443.JavaMail.jive@jiveforum2.autodesk.com... > You will need to alter the grading criteria, under the settings tab in the toolspace, expanding grading, then expand criteria sets. Under standard sets you will find the standard criteria you are using. You can then right click and choose edit.
nzeeben
Your picture is of the grading layout tools dialog. You need to access the settings from the settings tab of the toolspace. You will then be able to adjust if a value is locked or unlocked.
The problem was the dwg. I Have try with a new one and everything ok. Thanks a lot :-) "nzeeben" escribió en el mensaje news:5253555.1104859955772.JavaMail.jive@jiveforum2.autodesk.com... > Your picture is of the grading layout tools dialog. You need to access the settings from the settings tab of the toolspace. You will then be able to adjust if a value is locked or unlcoked.
nzeeben
No problem
Rail Community
