anyone seen instabilities with the grading tools? i am running C3D 2010 SP2, win7 64bit, 8GB RAM; am trying to create a dynamci FL from a profile, then use grade to a surface at 0% grade (trick it with 0.00001%). it has been crashing incessantly. the existing surf is DS, current file size is small (800 kb). anyone has any suggestions?
Yes - I've found the grading object to be a bit "buggy" on accasions
Can you grade successfuly at steeper slopes say 5%??
neilyj (No connection with Autodesk other than using the products in the real world)
I came across to same instabillity but I've noticed that most of the times it helps if you post-process the original FL to simplify it (weed and fit curves).
If you search the forums you will find MANY complaints about grading issues. It has been an achilles heal for C3D since the beginning and won't likely go away for a while based on the history of the problem. In fact the instability problems with grading are a major reason why we have not been using C3D even through 2011.
