In the grading tutorials for AutoCAD Civil 3D 2014 whenever I click "Grading Group Properties" in the Grading Creation Tools toolbar, it opens a dialog box I beleive is called Select Grading Group, or something similar. It does not open Grading Group Properties. This happens in every exercise I try. For example, I am trying to do Exercise 1: Smooth Feature Line Arcs at present. The previous exercise: Exercise 3: Filling Holes In A Grading, the exact same thing happened when I tried to open Grading Group Properties. I am running Windows 7 Ultimate with a GTX570 card, 16GB's RAM, AMD Phenom II CPU. So, I don't think I should have any problems with having the proper equipment. Is anyone eles having this same glitch? I can't do the grading tutorials without being able to access this dialog box. Any and all help or suggestions will be greatly appreciated. Thanks!
Solved by troma. Go to Solution.
Mark Green
Working on Civil 3D in Canada
I don't know how it happened. I thought I had created the gradings in the previous lessons. I started back at the beginning, and now everything is fine. I must have skipped one of the exercises inadverdently. Thanks!
