Civil 3D Forum
Grading Group Properties
2 REPLIES 2
323 Views, 2 Replies
In the grading tutorials for AutoCAD Civil 3D 2014 whenever I click "Grading Group Properties" in the Grading Creation Tools toolbar, it opens a dialog box I beleive is called Select Grading Group, or something similar.  It does not open Grading Group Properties. This happens in every exercise I try. For example, I am trying to do Exercise 1: Smooth Feature Line Arcs at present. The previous exercise: Exercise 3: Filling Holes In A Grading, the exact same thing happened when I tried to open Grading Group Properties. I am running Windows 7 Ultimate with a GTX570 card, 16GB's RAM, AMD Phenom II CPU. So, I don't think I should have any problems with having the proper equipment. Is anyone eles having this same glitch? I can't do the grading tutorials without being able to access this dialog box. Any and all help or suggestions will be greatly appreciated. Thanks!
2 REPLIES 2
troma
What happens if you select a grading group in that box that you do have, an click OK?
Is there a grading group in the drawing? If not, you will have to create one before accessing its properties.
Mark Green
Working on Civil 3D in Canada
I don't know how it happened. I thought I had created the gradings in the previous lessons. I started back at the beginning, and now everything is fine. I must have skipped one of the exercises inadverdently. Thanks!
Rail Community
