I have a feature line that is below the surface of an existing earth dam embankment. I want to grade downward from that feature line at a shallow slope until it daylights somewhere down the embankment slope. How do I accomplish this? All I can get it to do is slope upward (cut) to the existing surface.
Solved by Neilw_05. Go to Solution.
Can you post a picture? I can't see why it couldn't be done when I sketch you description.
One option is to over grade at you slope make a surface, compare and plot the zero contout to find you daylight.
Look at the help file for the setting shown in this screen capture.
Here is what you do. Create a temporary surface with the slope you are looking for from the feature line. Make sure that temporary surface extends beyond the limits of the earthen dam.
Then create a TIN volume surface between the earthen dam and your temporary surface. use a surface style on the volume surface you can see contours on. Create a user defined contour at elevation 0. This will be the intersection between you temporary slope and the earthen berm.
Extract the 0 elevation contour and use it to get elevations from your earthen berm surface. Add it to a new surface with your original feature line... There you go!
@d1of2 wrote:Here is what you do. Create a temporary surface with the slope you are looking for from the feature line. Make sure that temporary surface extends beyond the limits of the earthen dam.
You could also omit the italicised section and simply use the MinimumDistBetweenSurfaces tool (best used in 2012/2013 as this creates a 3D polyline but 2011 can be used with a little more work)
neilyj (No connection with Autodesk other than using the products in the real world)
Guys, I think you are making this far too complicated. All you need to do is change that search order setting to Fill First and the grading will then look for a solution downward rather than upward when in cut.
Good one Neil, I never saw that setting
I appreciate the responses. My immediate need was solved by setting fill first. There are other issues with trying to grade this project that have me reaching for the gun. I was doing this type of stuff easily with simple add-on tools twenty years ago. Why simple tasks have to be so complicated in Civil 3D is beyond me. Sorry, had to vent! I do appreciate the help.
They really meant it when they said forget everything you new about (LDT) or other apps; didn't they?
One thing that I have adopted and has been working for me is compartmentalize grading. I no longer look for the finished product from one tool or one pass of a grading app, but start off thinking in very general terms and refine as I go.
If you set out setting final grades in your first pass you are only setting yourself up for disappointment. Look at it like a big block and chisel away small pieces at a time.
