I do not have any of the default surface styles loaded. Like the 1' and 5' contours (design). Can I find these somewhere? If not, I will just have to make them.
Also, When I grade and create a surface my cut and fill areas do not show up as green and red like ive seen on others. How can I change this? Thanks!
Solved by Pointdump. Go to Solution.
Kyle,
Open up your Imperial Template, thusly:
You'll find lots of Surface Styles:
Dave
Dave Stoll
Las Vegas, Nevada
Kyle,
You can Drag-n-Drop Styles from one drawing to another.
Dave
Dave Stoll
Las Vegas, Nevada
Oh, and you can also Import Styles, thusly:
Dave
Dave Stoll
Las Vegas, Nevada
