Civil 3D Forum
Grading criteria duplicates
6 REPLIES 6
Joe-Bouza
408 Views, 6 Replies
I think I know how these duplicates got into my template file (but not really). The problem I have when I try to delete anyname.1 they all get deleted. Anyone know how I can clean this up without loosing them all?
Your Name
6 REPLIES 6
jmayo-EE
in reply to: Joe-Bouza
Do you insert other C3D files as blocks or use the clipboard to bring C3D gradings into other files? I think that's the culprit. Perhaps importstylesandsettings? I'm not positive the styles import will do that but more important, what are you doing? 🙂
John Mayo
Joe-Bouza
in reply to: jmayo-EE
I suspect the same but I'm not prone to doing any inserts in the dwt (I must have to get what I got)
Your Name
jmayo-EE
I don't have time to test this today and I'm not positive which of the three will trigger it but I have seen the dups in my files as well. It's pretty harmless but you should clean up the template.
John Mayo
Joe-Bouza
Yes. That is my goal but when I delete one of the dups it deletes all the criteria?
Your Name
jmayo-EE
That sholdn't happen. Are you attempting this from the propsector pane below the one in your post? I have had trouble deleteing more than one at a time (quick fix by holding ctrl button while right clicking to delete).
I typically select multiple criteria in the lower pane and all works fine. Have you checked the file for errors?
John Mayo
Joe-Bouza
I caved in a renamed them for ligitamate use. Example I had grade to surface 1:3 default, and the dupe I change to X%
Your Name
Rail Community
