I don't know if "Station Marker Style" is the correct term/word. Anyway, I'm looking for the setting to change the style for the "triangle" when a particular station is selected.
Thank you in advance!
Solved by AllenJessup. Go to Solution.
I don't believe that is something that can be changed. Would be nice to change it though.
Too bad, I want to control the size of that triangle.
Perhaps it can be changed when you change your osnap aperture size or something along those lines. It might be worth checking out. Also, there may be something in the properties on the AEC tab(s). I don't have C3D on this computer so I can't check it for you.
It's called a Transient Glyph. I don't know of any way to affect it.
Allen
Allen Jessup
CAD Manager - Designer
Thank you, all of you 🙂
