Hello;
My alignment has vertical geometry text assigned to it for display purposes on plan view, however, I get the "???" on the GRADE IN and GRADE OUT at the ends of my alignment. Please see capture screen below. Is there a way to OMIT the Grade In ??? designation at the beginning and end of the alignment?
Thank you
Milena Aguirre, PE
Solved by Bill_Myron. Go to Solution.
Solved by Joe-Bouza. Go to Solution.
Joe Bouza
