Hello all, this may have a simple solution but I just can't get it.
I have a profile set up with a surface an alignment and a Water Main. I would like to place grade breaks (Using Profile labels) every 100' along the surface however the increment field isn't available for grade breaks. Weeding doesn't help becuase it needs to be exactly every 100' I was thinking of creating an expression for it however I still haven't reached that level of expertise.
Thanks!!
Are the labels required in plan or profile? What exactly do you mean by "gradient breaks", can you supply a sketh or image showing what you are trying to achieve?
If you mean to show levels in plan then use "alignment labels", chainage / stations. Edit style, add referance text > Profile > Profile Elevation then set to 100' increments.
If gradients same as above only "instantaneous grade", which should give you the grade at the sampled point.
