Civil 3D Forum
Google Earth units
8 REPLIES 8
Message 1 of 9
Joe-Bouza
477 Views, 8 Replies
Google Earth units
My drawing is set to state plane  and feet. when I import GE the elevations are different that thos reproted on the GE screen. For example at a given location GE reports 538 but the c3d surface  report 164 a factor of 3.28. sounds like a meter thing going on. is this normal? can It be adjusted?
Your Name
Your Name
8 REPLIES 8
Message 2 of 9
KenPrzybysz
in reply to: Joe-Bouza
I've gotten around this by typing UNITS at the command line and setting the "Insertion Units" to Feet.
Message 3 of 9
Joe-Bouza
in reply to: KenPrzybysz
Perfect!
Thanbks Ken
Your Name
Your Name
Message 4 of 9
KenPrzybysz
You're welcome! Trying to start to give back to the boards when I can!
Message 5 of 9
Joe-Bouza
Got get em!
Hey you got 1 kudo for 3 post. You'd be heading for Cooperstown with numbers like that Smiley Wink
Your Name
Your Name
Message 6 of 9
Kyle-Evans
Yes Joe, this is a Feet to Meter thing. There are 3.28 Feet per Meter, just to clarify a tiny bit here!
Message 7 of 9
Joe-Bouza
in reply to: Kyle-Evans
Hi Sindarin,
That much I got. But if GE is saying feet and my c3d says feet other than acad units were unitless why would it come in in meters?
Your Name
Your Name
Message 8 of 9
Kyle-Evans
Hey Joe, not much work to do today I see... Instant replies!!! *forget I said that*
I have had that problem in Civil 3D 2011 as well. If I imported something into my drawing, it would show up in inches, and put itself out way in outer space, but if I copy and pasted it, it would show up properly.
Both my drawings and units were set up to be the exact same, so I have no clue what happened.
Under your Toolspace drawing settings, what is your drawing units set up too? That may have something to do with it. Also make sure the "Scale objects inserted from other drawings" is selected.
Give that a try I guess.
Message 9 of 9
Joe-Bouza
(I waited a few minutes this time)
Thankes I see the check boxes that apply. Thats a big help.
Your Name
Your Name
Rail Community
