Joe-Bouza
Message 1 of 9 (322 Views)
Google Earth units
322 Views, 8 Replies
01-22-2013 08:09 AM
My drawing is set to state plane  and feet. when I import GE the elevations are different that thos reproted on the GE screen. For example at a given location GE reports 538 but the c3d surface  report 164 a factor of 3.28. sounds like a meter thing going on. is this normal? can It be adjusted?
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
I've gotten around this by typing UNITS at the command line and setting the "Insertion Units" to Feet.
Member
KenPrzybysz
Message 2 of 9 (319 Views)
Re: Google Earth units
01-22-2013 08:13 AM in reply to: Joe-Bouza
Joe-Bouza
Message 3 of 9 (311 Views)
01-22-2013 08:19 AM in reply to: KenPrzybysz
Perfect!
Thanbks Ken
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Member
KenPrzybysz
Message 4 of 9 (302 Views)
01-22-2013 08:30 AM in reply to: Joe-Bouza
You're welcome! Trying to start to give back to the boards when I can!
Joe-Bouza
Message 5 of 9 (299 Views)
01-22-2013 08:33 AM in reply to: KenPrzybysz
Got get em!
Hey you got 1 kudo for 3 post. You'd be heading for Cooperstown with numbers like that :smileywink:
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Valued Mentor
Sindarin
Message 6 of 9 (294 Views)
01-22-2013 08:35 AM in reply to: Joe-Bouza
Yes Joe, this is a Feet to Meter thing. There are 3.28 Feet per Meter, just to clarify a tiny bit here!
Joe-Bouza
Message 7 of 9 (286 Views)
01-22-2013 08:41 AM in reply to: Sindarin
Hi Sindarin,
That much I got. But if GE is saying feet and my c3d says feet other than acad units were unitless why would it come in in meters?
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
Valued Mentor
Sindarin
Message 8 of 9 (283 Views)
01-22-2013 08:44 AM in reply to: Joe-Bouza
Hey Joe, not much work to do today I see... Instant replies!!! *forget I said that*
I have had that problem in Civil 3D 2011 as well. If I imported something into my drawing, it would show up in inches, and put itself out way in outer space, but if I copy and pasted it, it would show up properly.
Both my drawings and units were set up to be the exact same, so I have no clue what happened.
Under your Toolspace drawing settings, what is your drawing units set up too? That may have something to do with it. Also make sure the "Scale objects inserted from other drawings" is selected.
Give that a try I guess.
Joe-Bouza
Message 9 of 9 (274 Views)
01-22-2013 09:15 AM in reply to: Sindarin
(I waited a few minutes this time)
Thankes I see the check boxes that apply. Thats a big help.
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
