I have simply been given pipeline survey data.
How can I make profiles of the pipe line?
Attached is a screan shot of the points, line work was processed durring inport but you can see that linework was only created in certian areas.
Joy
Solved by BrianHailey. Go to Solution.
Create a surface from the points (take your 3D plines and create offsets of them and add them to a surface). Create alignments from your pipes. Create surface profiles.
