Civil 3D Forum
gis coordinate system display in civil 3d 2015
4 REPLIES 4
aluko0719
4315 Views, 4 Replies
in civil 3d 2014 on the bottom of the screen you could dislpay the coordinate system. is there a way to show this in civil 3d 2015?
4 REPLIES 4
Try running the command "mapstatusbar" and then "s" for show.
This should turn on the map coordinate display and map scale displays on.
If a post provides a fix for your issue, click on "Accept as Solution" to help other users find solutions to problems they might have that are similar to yours.
Andrew Puller
Maitland, NSW, Australia
Windows 10 Enterprise 64bit
Intel core i7 11800 @ 2.30 GHz with 32GB Ram
Civil 3d 2021
txrain
in reply to: andrewpuller3811
Thanks!
Cadguru42
in reply to: aluko0719
It's also on the bottom right corner of the status bar. You'll see a button with three bars. Click that and you'll get the list of all the status bar toggles you can turn on/off, including coordinates.
C3D 2022-2024
Windows 10 Pro
32GB RAM
Thank you andrew puller.  Why that is not included in the status bar customization, and why it is turned off by default, only some brilliant programmer at autodesk knows.
Rail Community
