in civil 3d 2014 on the bottom of the screen you could dislpay the coordinate system. is there a way to show this in civil 3d 2015?
Solved by andrewpuller3811. Go to Solution.
Try running the command "mapstatusbar" and then "s" for show.
This should turn on the map coordinate display and map scale displays on.
@aluko0719 wrote:in civil 3d 2014 on the bottom of the screen you could dislpay the coordinate system. is there a way to show this in civil 3d 2015?
It's also on the bottom right corner of the status bar. You'll see a button with three bars. Click that and you'll get the list of all the status bar toggles you can turn on/off, including coordinates.
Thank you andrew puller. Why that is not included in the status bar customization, and why it is turned off by default, only some brilliant programmer at autodesk knows.
