Active Contributor
3 Kudos
Post 1 of 5
gis coordinate system display in civil 3d 2015
1890 Views, 4 Replies
04-10-2014 10:04 AM
in civil 3d 2014 on the bottom of the screen you could dislpay the coordinate system. is there a way to show this in civil 3d 2015?
Try running the command "mapstatusbar" and then "s" for show.
This should turn on the map coordinate display and map scale displays on.
Distinguished Mentor
126 Kudos
Post 2 of 5
Re: gis coordinate system display in civil 3d 2015
04-11-2014 05:36 AM in reply to: aluko0719
If this fixed your issue, click on "Accept as Solution"
Andrew Puller
Maitland, NSW, Australia
Windows 7 Enterprise 64bit
Intel core i7 2600 @ 3.40 GHz with 16GB Ram
Civil 3d 2013 64bit
New Member
0 Kudos
Post 3 of 5
06-25-2014 06:01 PM in reply to: andrewpuller3811
Thanks!
Valued Mentor
66 Kudos
Post 4 of 5
06-26-2014 05:32 AM in reply to: aluko0719
It's also on the bottom right corner of the status bar. You'll see a button with three bars. Click that and you'll get the list of all the status bar toggles you can turn on/off, including coordinates.
IDSP 2015
Windows 8.1 Pro 64-bit
8GB RAM
Active Contributor
2 Kudos
Post 5 of 5
09-30-2014 10:19 AM in reply to: andrewpuller3811
Thank you andrew puller.  Why that is not included in the status bar customization, and why it is turned off by default, only some brilliant programmer at autodesk knows.
