So I am pretty new to Civil 3D and had to jump into the middle of a project. The Viewframes were already created but when I go to the plan and profile sheets for the viewframes the profile is not showing and I'm not sure how to choose the correct profile and display it in the corresponding plan and profile sheet.
Solved by Jay_B. Go to Solution.
In the Plan and Profile sheets go to Model Space of viewport>select grid>rt. click>profile view properties>profiles Tab>
Are there any profiles listed and is "Draw" column checked?
Sounds like starting over from scratch and recreating the viewframes would be a good idea.
Did you use the Wizard to create profile views or choose option to get settings from another profile view?
We use the Wizard, then the profile view is generated within MS of the viewport (like per sheet) When prompted for profile origin just make sure to pick a blank point in space so references wont appear in your profile area.
