Civil 3D Forum
getting close...another corridor question...
2 REPLIES 2
ces
248 Views, 2 Replies
well, now (with plenty of help from you guys) I have a corridor with multiple baselines and regions. it all looks pretty good, now I just need to figure out how to get the top and battom data out of my corridor and into a couple of surfaces. I believe (I hope) I am nearly home and this should be fairly easy. any help with this will be greatly appreciated.
thanks...
2 REPLIES 2
sboon
in reply to: ces
The section points, links and the feature lines you have created in your corridor all have codes attached to them.  When you create a corridor surface you can choose which objects you want to use in the surface definition by those codes.
If you open the corridor properties dialog and switch to the Surfaces tab you will be able to create two new surfaces and add definition data to them.  See this link for a tutorial.
Steve
Expert Elite Alumnus
ces
in reply to: sboon
thanx Steve...
Rail Community
