well, now (with plenty of help from you guys) I have a corridor with multiple baselines and regions. it all looks pretty good, now I just need to figure out how to get the top and battom data out of my corridor and into a couple of surfaces. I believe (I hope) I am nearly home and this should be fairly easy. any help with this will be greatly appreciated.
thanks...
Solved by sboon. Go to Solution.
The section points, links and the feature lines you have created in your corridor all have codes attached to them. When you create a corridor surface you can choose which objects you want to use in the surface definition by those codes.
If you open the corridor properties dialog and switch to the Surfaces tab you will be able to create two new surfaces and add definition data to them. See this link for a tutorial.
