Civil 3D Forum
GeoTIFF surface limitations
3 REPLIES 3
neilyj666
216 Views, 3 Replies
I've received a humungous xml file (1.2Gb) and have eventually created a surface in Civil (1m data point spacing) and I have exported a Geotif (DEM doesn't work in Great Britain Coord System...!!!) with a more manageable 5m data point spacing
I created a surface from the geotiff and need to exchange the surface with another software product but there don't appear to be many options to do this easily. I can't XML the geotiff surface so I have displayed the points and am extracting them to create a dxf file
Is there a better way to do this or is geotiff a very restrictive method for creating and exchanging surfaces?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
3 REPLIES 3
rl_jackson
in reply to: neilyj666
Have you considered exploding your surface so that you get the TINN Lines. I think Jeff, posting a process some time ago about how to extract the TINN lines from a C3D surface. That might work if the other software can create a surface from the linework.
Rick Jackson
Survey CAD Technician VI
ksorsby
I had a similar thing with a large point cloud (316 million points!). I found the best and most reliable way was to extract raw autocad points from the surface then export those to a .csv or .xyz file using a lisp file we have.
Don't do the cogo point to point file method. It's clunky and seems to take forever.
Never had much luck or reliability with xml's or geotifs so as always, simplest is best in my opinion!
Cheers,
Kevin
antoniovinci
If the second software needs a vector drawing, I'd go with contours, just because the number of 3Dfaces would be inacceptable...
Rail Community
