Hello , I have problem about Geotechincs Module 2015 in AutoCAD Civil3D 2015.
when i try to click "Import" in module it shown error message below "Unable to connect to the database"
i try to re-install the module and try to delete C:\ProgramData\Keynetix
but cannot fix probem.
Help me please
do you have Map 3D 2015 installed on the same computer and do you have Service Pack 3 applied?
If so, please uninstall Service Pack 3 and let me know if that solved the issue.
(Windows Start -> Control Panel -> Programs and Features -> View installed updates (top left))
Best Regards,
Karsten.
Was a solution to this problem ever found?, because I have the same problem in C3D 2015.
Thanks in advance for any help
UPDATE:
I uninstalled Map 3D Service Packs 2 and 3 and the Geotechnical module now works.
I know this is only a temporary fix as you may well require those SP's
I'll update as I discover more.
