Civil 3D Forum
Geotechnical Module v1 update now available!
16 REPLIES 16
Message 1 of 17
jessica.kelly
4375 Views, 16 Replies
We are pleased to announce the release of Geotechnical Module v1 for both Civil 3D 2013 and Infrastructure Design Suite 2014.
These are now available for download on Subscription Center along with release notes. Please uninstall any previous version of the Geotechnical Module prior to installing Geotechnical Module v1.
Thank you!
Jessica L. Kelly
Director, Operations - Autodesk Tandem
16 REPLIES 16
Message 2 of 17
ScotBIM
in reply to: jessica.kelly
Uninstalled the previous version . .  but getting the error message:
On Civil3d 2013.
Message 3 of 17
ScotBIM
- solved, the installation pack here is for version 2014 only, and not as described in the email I recieved:
Message 4 of 17
My apologies for not clarifying the specific locations in my initial email.
The 2014 version of Geotechnical Module is avaialable to Infrastructure Design Suite Premium and Ultimate Customers on Subscription Center. Choose to "View all available Product Enhancements" and you will see the Geotechnical Module listed. Once you click on that link, you will see the download for v1.
The 2013 version of Geotechncial Module is avaialable to Civil 3D 2013 Customers on Subscription Center. Choose "Productivity Tools for AutoCAD Civil 3D 2013" and you will see the Geotechnical Module listed on that page with the download links.
Please let me know if you have any further questions.
Jessica L. Kelly
Message 5 of 17
neilyj666
The Geotechnial Module is no longer working....the popup say it has been succesfully loaded but when the import button is clicked...
Command: KYN_ImportAGS Unknown command "KYN_IMPORTAGS".  Press F1 for help.
The only change (apart from standard Windows updates) is that I have installed the CodeExecutionVulnerability Hotfix .
I have uninstalled and reinstalled the Geotech module but it still doesn't work
Any suggestions?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 6 of 17
neilyj666
in reply to: neilyj666
Just uninstalled the module
Rebooted
Deleted the getechnicalmodule.bundle folder in the applicationplugin folder
Reinstalled the module
Still doesn’t work..
Am getting desperate now - it actually worked on Wednesday after installing the CodeExecutionVulnerability Hotfix but failed to work on Friday and hasn't since...
I am getting increasingly frustrated by this Geotechnical module; I don't get this kind of hassle when using Mapworks Geotechnical module....
Message 7 of 17
neilyj666
Hurrah - just had a long support call to try and sort out this geotechnical module and it is working again
Not sure why it wasn't working but the solution was to uninstall the module and delete the folder C:\ProgramData\Keynetix\AutodeskGeotechnicalModule, reinstalled and worked just fine
Kudos to GaryMorin8439 @ Keynetix for the help
Message 8 of 17
mconway
Thanks for this post!
I just wanted folks to know that there is no need to uninstall and reinstall the module. Simply Deleting the C:\ProgramData\Keynetix\AutodeskGeotechnicalModule folder will allow the module to work. Civil 3D will remake this folder upon restart of the module.
At your service,
Mark A. Conway
Director - Applied Technology
Autodesk Certified Instructor
AutoCAD & Civil 3D 2014 Certified Professional
Infrastructure Design Suite BIM Specialist
Follow me on Twitter @CADventurer
Tags (1)
Message 9 of 17
prasad.pandit
in reply to: mconway
Hi There is a need to uninstall the application. I think following are the steps which I recommend for Geotechncial Module install issues with Unknown Command Errors.
  1. Uninstall 2013, 2014, 2015 Geotechnical (Side by Side gives some trouble)
  2. Download Geotechncial V1 from Subs (For 2014) if you have not already (Wasn't a problem for me since I was using V1)
  3. Delete folder C:\ProgramData\Keynetix
  4. Install ONLY 2014 at the moment since it is not released yet.
  5. Don’t forget to REBOOT Smiley Happy
  6. Start Civil 3D 2014.
  7. Save the Drawing before Cicking IMPORT
  8. USE Geotechncial comfortably. Smiley Very Happy
Cheers..
Prasad Pandit
Technical Account Manager
Enterprise & Goverment
Enterprise & Government
INDIA & SAARC
Message 10 of 17
ScotBIM
in reply to: prasad.pandit
AutoCAD Message:
SQL Compact Edition has not been detected, please install the drivers for SQL Compact Edition 4.0.
Message 11 of 17
h.malgarezi
Where can I download Geotechnical Module and Bridge Module for Civil 3d 2015??
The one I found at Subscription Center is only for 2014 and 2013 versions...
Message 12 of 17
cbaildon001
in reply to: h.malgarezi
I downloaded it here.
http://subscription.autodesk.com/sp/servlet/download/item?siteID=11564774&id=23493689
But I get this error message when I try to import data ( I want to import CSV data).
Command "KYN_ImportAGS"
Any ideas?
Cheers
Caleb Baildon
Senior Surveyor
Opus International Consultants Ltd
Wellington, New Zealand
Civil3D 2015 - Windows10
Message 13 of 17
jessica.kelly
in reply to: cbaildon001
Can you look in the About Box and let me know exactly which version you are currently using?
Thanks!
--Jessica Tarr
Product Manager
Jessica L. Kelly
Message 14 of 17
cbaildon001
Hi Jessica
The Geotechnics version is 1.16.0.2.
The command now works, but I have lost the ribbon. I have uninstalled and reinstalled and still no ribbon. Where do I find the partial cuix to load?
Cheers
Caleb Baildon
Senior Surveyor
Message 15 of 17
when i try to uninstall geotechnical module civil 3d 2014 thru control panel, it is giving error 2343. i am trying to uninstall all autodesk programs so that i can install the revit 2015
Message 16 of 17
hello!
anybody know if this module is still available, I have a Customer to ask about this one,
thanks in advance.
Simon Noyola
Down to Earth Technolgies, inc
Message 17 of 17
Attached I have a sceenshot taken from my autodesk account. Please note that I do not have the option to download the Geotechnical Module "Enhancements". Please advise me on how can I download the geotechnical module for autocad civil 3d 2013 and 2016?
Much Thanks,
Alex
Rail Community
