Anyone having stability issues with the Geotech module in 2014?
Seems it takes forever to respond to changing styles/views/visual styles etc and Civil 3D goes into the classic dimmed screen and "Not Responding" mode
neilyj (No connection with Autodesk other than using the products in the real world)
Solved by jessica_kelly. Go to Solution.
If you have a current Subscription, then it is available for download from the Subscription Centre; if you do not, then it is not available via this route and you will have to purchase the equivalent software from the original software authors (www.keynetix.co.uk)
The link shows this:
The theory is that since Civil 3D is a "Subscription Only" product. The Geotech module is included with the Subscription Software. I've not seen it ship or download with the original program.
No need to apologize. Your English is easily understandable.
Allen
Allen Jessup
CAD Manager - Designer
Interestingly, this link http://www.autodesk.com/suites/infrastructure-design-suite/compare/compare-edition-features show that all the tools are only available for IDSU only rather Rail/Bridge/Geotech being available for IDSP. It would certainly appear that the module is only available via subscription.
That's how I got it with IDSP.
Allen
Allen Jessup
Hello, everyone. I have a problem with boreholes' "z" values when i am working with geotechical module. Please help and thank you.
To explain you better I will give you an example – the attached filesJ
I suspect it is because the standard vertical exaggeration in Geotech module is 5; thus 168.88 x 5 = 844.4, resetting it to 1 will give results as expected. The surfaces dervived should be correct
