Civil 3D Forum
Geotechnical Module recommended to be uninstalled
23 REPLIES 23
Message 1 of 24
neilyj666
2264 Views, 23 Replies
From this thread http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Geotechnical-Module-Stability-in-2014/td-p/3940095 the current (30 May) advice from Autodesk is to uninstall the Geotechnical module due to "performance issues"
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
23 REPLIES 23
Message 21 of 24
neilyj666
in reply to: jessica.kelly
Jessica
I'll just post them up here so others can comment as well...
1. The ability to Shift Click or Crtrl Click multiple boreholes to toggle the tick boxes for strips etc. Whilst it is possible to Shift click and Ctrl Click to select multiple boreholes (for Ctrl-C and Ctrl-V to Excel see 2. below) it is only possible to tick each borehole/trial pit individually which is very tedious - this is a "must do" sooner rather than later.
2. Whilst the ability to turn on/off strata surfaces is welcome, the fundamental flaw in this approach is that each stratum is built up from the absolute level in each borehole. This may not be a major problem with a relatively flat site but in steep mountainous or undulating terrain the surfaces become a bit pointless. What is required is the ability to use the borehole depths to create a surface and then use other Civil 3D techniques to develop a stratum surface that more accurately reflect the ground topography (whilst appreciating that this is not always true). As intimated in 1 above, standard Windows copy and paste techniques can be used to generate the relevant files via Excel but it would be good if the geotech module could generate Point Groups of this information - all the information is present but it is not easy to extract especially from a native ags file.
Message 22 of 24
mbravo_terra
in reply to: neilyj666
Igual al momento de trabajar los archivos en red local produce este error, si alguien tiene alguna solucion se los agradeceria mucho ahi les dejo una imagen del mismo!
Gracias..!
Message 23 of 24
mbravo_terra
As when working in local network files this error occurs, if anyone has any solution would greatly appreciate there are those I leave a picture of it!
Thank you ..!
Message 24 of 24
neilyj666
in reply to: mbravo_terra
Not sure what this means - can you post your CSV/AGS files an I'll see if I can reproduce it....
...and after Google translate.....
No estoy seguro de lo que esto significa - ¿puedes postear tus archivos CSV / AGS una Veré si puedo reproducirlo.
Rail Community
