Civil 3D Forum
Geotechnical Module for Civil 3D: import error
14 REPLIES 14
Message 1 of 15
a.zemlyanskaya
2717 Views, 14 Replies
Hello there,
I try to import geotechnical data into Civil 3D 2014 but see this message: Object reference not set to an instance of an object
Вoes anyone know what could be wrong?
14 REPLIES 14
Message 2 of 15
neilyj666
in reply to: a.zemlyanskaya
What method are you using to import - AGS or GEOL/HOLE.csv?
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 3 of 15
a.zemlyanskaya
in reply to: neilyj666
t was import from CSV file. I used this set of data http://kbs.keynetix.com/node/446/488
Message 4 of 15
neilyj666
When I try yo download them they get saved as GEOL_0.csv and HOLE_0.csv which won't work.
Rename them to the correct names i.e. GEOL.csv and HOLE.csv
Message 5 of 15
a.zemlyanskaya
уes, I know, it was the first thing I did.
there is problem not with the data but in Civil 3D, I believe
Message 6 of 15
neilyj666
Worked for me with no issues.....apart from crashing as soon as I took the screenshot to post....Smiley Frustrated
Message 7 of 15
I'm suspecting a mismatch between the two files. One file doesn't match the other.
Try my sample files - they import ok.
http://sdrv.ms/10xF2Ks
Eric Collins, P.Tech.(Eng.)
Win 10
Intel i7 9700 @ 3 GHz
16 GB RAM
Civil 3D 2019
Message 8 of 15
vtjp
in reply to: ericcollins6932
I have same problem. Fresh Civil 3D 2014 installation. Have tried both csv -files (from Keynetix and also Eric's offered) but no luck. Same window and when accepting it just not doing anything
Message 9 of 15
I also encountered the error this week. I restarted C3D and was ok after the restart.
Win 10
16 GB RAM
Civil 3D 2019
Message 10 of 15
vtjp
No help, still gives error.... any idea does this have some thing to do with unstabilitys of geo module?
Message 11 of 15
neilyj666
in reply to: vtjp
Not really sure - sometime the error messages are not helpful at all.
Probably worth checking the source csv files in Excel to ensure all the fields are present and correct and that all the holes referenced in GEOL are present in HOLE (and vice versa).
If that all checks out then it's got me beaten....
Message 12 of 15
magnus.svensson
Change Your regional settings from comma , to point . during import.
Message 13 of 15
mconway
in reply to: magnus.svensson
magnus.svensson, What do you mean by "Change Your regional settings from comma , to point . during import." where would I change these settings? Im getting the "object not set..." error as soon as I select the import button. I don't even get to the Data Files Dialog Box. Any Help is greatly qappriciated
At your service,
__________________________________________________
Mark A Conway –Director of Design Technology | Gilmore & Associates, Inc.
Autodesk Certified Instructor
AutoCAD Civil 3D Certified Professional
Autodesk Certified BIM Specialist for Roads and Highways
Message 14 of 15
autoMick
in reply to: mconway
You can set the delimiter (space, comma etc.) for the csv files when (and if) you get to the first dialog box
Civil3d user in Australia since 2012.
Message 15 of 15
I had the same error and was convinced I also had a bad install... Until I realised that the values that I was using for my northing, easting and ground levels still had the units in them (i.e. "m"). This is how they were imported from the points directly in C3D, so initially I hadn't thought to check them.
So this could be your problem as well. Just check the Keynetix website for examples of the GEOL.csv and HOLE.csv files and make sure yours comply.
Rail Community
