Civil 3D Forum
Geotechnical Module Add On for Civil 3D 2013 Subscription customers
38 REPLIES 38
Message 1 of 39
neilyj666
5009 Views, 38 Replies
From the blog  http://fromthegroundup.typepad.com/
Launched today for those customers with AutoCAD Civil 3D 2013, the Autodesk Geotechnical Module is available as a download from the subscription centre (www.autodesk.com/subscription ) under the ‘AutoCAD Civil 3D 2013 Productivity Tools’.
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
38 REPLIES 38
Message 2 of 39
neilyj666
in reply to: neilyj666
Been a bit busy today so haven't had a chance to play with it but it's installed and I have the relevant icons....
Message 3 of 39
It will be great to hear your feedback on the module.  This is the first release, so I'll be very keen to hear people's findings  and what work we may have to do to it.
Regards
Gary
Message 4 of 39
Import is giving me an error. Image of alert box attached.
Message 5 of 39
neilyj666
Did you install SQL Server as well?
Productivity Tools for AutoCAD Civil 3D 2013 - Mozilla Firefox_2013-02-06_21-56-30.jpg
Message 6 of 39
Nope. I jumped right over that. Thanks!
Message 7 of 39
Also remember for  this version your file names must be:
HOLE.csv and GEOL.csv
The case is important, We will change this is in the next release
Regards
Message 8 of 39
neilyj666
I've not tried the csv import yet but thanks for the heads up on case sensitivity
Message 9 of 39
neilyj666
Can't get the csv import to work at all - hopefully something simple wrong with my data files but I can't spot it.
Any one able to reproduce the problem?? Error messages in next post and .txt added to file name as .csv not permitted
Message 10 of 39
neilyj666
Error messages - later screen shot after changing file names to upper case
Message 11 of 39
I've repeated the problem, the need to spend a bit more time  checking the cause of it. when I have an answer I will get straight back to you.
Regards
Message 12 of 39
neilyj666
Many thanks Gary - I tend to get most of my SI data as pdf logs and so need to manually input rather than use the AGS route so csv method is essential for me.Smiley Happy
Message 13 of 39
I can't seem to find this module on the subscription pages. I know I need to have 2013 installed to use it, but I don't need it installed to find and download it do I?
Message 14 of 39
I found it....
in case anyone was wondering, the csv setup is here
http://kbs.keynetix.com/node/446/488
Message 15 of 39
neilyj666
???? csv input is broken at the moment....
Message 16 of 39
no, no i didn't mean it is broken, I just couldn't find out how the csv should be set up. What columns are what and in what order. The links above solved my problem... well at least this one.
Message 17 of 39
I just got chance to have a better look at your CSV files and found the cause of the problem.
You need to have Finaldepth in the HOLE.csv
Message 18 of 39
The sample csv files on http://kbs.keynetix.com/node/446/488 have just been updated. Use these as your template for CSV import
Message 19 of 39
neilyj666
Thanks for the update again, a fairly easy fix - the Finaldepth field wasn't mandatory in the original instructions was it??
Message 20 of 39
Yes, that is correct, an oversight in the documentation.
Let me know how you get on with it.
Regards
Gary
Rail Community
