From the blog http://fromthegroundup.typepad.com/
Launched today for those customers with AutoCAD Civil 3D 2013, the Autodesk Geotechnical Module is available as a download from the subscription centre (www.autodesk.com/subscription ) under the ‘AutoCAD Civil 3D 2013 Productivity Tools’.
neilyj (No connection with Autodesk other than using the products in the real world)
Been a bit busy today so haven't had a chance to play with it but it's installed and I have the relevant icons....
It will be great to hear your feedback on the module. This is the first release, so I'll be very keen to hear people's findings and what work we may have to do to it.
Regards
Gary
Did you install SQL Server as well?
Also remember for this version your file names must be:
HOLE.csv and GEOL.csv
The case is important, We will change this is in the next release
Regards
I've not tried the csv import yet but thanks for the heads up on case sensitivity
Can't get the csv import to work at all - hopefully something simple wrong with my data files but I can't spot it.
Any one able to reproduce the problem?? Error messages in next post and .txt added to file name as .csv not permitted
Error messages - later screen shot after changing file names to upper case
I've repeated the problem, the need to spend a bit more time checking the cause of it. when I have an answer I will get straight back to you.
Regards
Many thanks Gary - I tend to get most of my SI data as pdf logs and so need to manually input rather than use the AGS route so csv method is essential for me.
I can't seem to find this module on the subscription pages. I know I need to have 2013 installed to use it, but I don't need it installed to find and download it do I?
I found it....
in case anyone was wondering, the csv setup is here
no, no i didn't mean it is broken, I just couldn't find out how the csv should be set up. What columns are what and in what order. The links above solved my problem... well at least this one.
I just got chance to have a better look at your CSV files and found the cause of the problem.
You need to have Finaldepth in the HOLE.csv
The sample csv files on http://kbs.keynetix.com/node/446/488 have just been updated. Use these as your template for CSV import
Thanks for the update again, a fairly easy fix - the Finaldepth field wasn't mandatory in the original instructions was it??
