Civil 3D Forum
GEOMAPIMAGE 2015 - Where is the image saved?
4 REPLIES 4
488 Views, 4 Replies
When capturing an image from Bing using the GEOMAPIMAGE command, where is the image saved? I can't see it in the Xref manager.
Where is it?
Cheers
4 REPLIES 4
antoniovinci
Did you look for in the folder where you saved the current DWG..?
in reply to: antoniovinci
Yes, I did and it's not there.
Is it supposed to be there?
mathewkol
It's not an XREF, it is saved in the DWG.  Look at your file size before and after you've captured the image.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
in reply to: mathewkol
Thanks Matt. That is what I suspected, but I hadn't looked at the file size, but yes it does jump up in size.
Rail Community
