Question about Geomap...I sign into Autodesk360, set my co-ordinate system, type geomap then select aerial, I can see Civil thinking, but no map shows up? Am I missing something ?
Thanks in advance for any help, greatly appreciated...
Solved by tcorey. Go to Solution.
After using this command more, I have noticed if Iimport a shapefile first the geomap command works just fine bringing in the Bing imagery. That can not be how this command works since every drawing does not have a shape file imported into to it.
Any assistance would be greatly appreciated....
It works fine if you zoom to coordinates that are within the coordinate system assigned to your drawing.
In my case, California State Plane Zone 1, US Feet, NAD83. I zoom to 6 million, 2 millon and 6.1 million, 2.1 million then I see the attached geomap.
Tim
