AutoCAD Civil 3D General Discussion
*Expert Elite*
343 Kudos
Post 1 of 4
Geological models and showing strata in cuts
392 Views, 3 Replies
05-22-2013 12:45 AM
I'm trying to explore possible options for displaying 3D geology models. In the attached I want to chop out the yellow solid and leave the other solids "as is" to reveal the various strata when the yellow solid is removed. I have removed the yellow solid but the results are not quite what I was hoping for.
Can this be done?
(I have also posted in the AutoCAD forum but there is so much spam in there......)
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 500Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
11 Kudos
Post 2 of 4
Re: Geological models and showing strata in cuts
05-22-2013 02:59 AM in reply to: neilyj
I did a quick test which seemed to do what you want. There's probably better ways, I did this:
- draw your 3D layers (I just used boxes)
- draw your cutting object and convert it to a nurbs surface (mine was a sphere as you can see in the pic)
- use the slice command. Select each stratum
- use the surface option for your slicing object
Cheers
- Mick
Infrastructure Design Suite Premium 2015 SP1
Self-built i7-3930K, 16Gb RAM, P9X79 m/board
SSD(system), HDD(data), Win7Pro64, Quadro K4000 (and another with GTX680)
*Expert Elite*
343 Kudos
Post 3 of 4
05-22-2013 03:05 AM in reply to: autoMick
Thanks for this - exactly what I was trying to do...:smileyhappy:
How do I convert to NURBS surface?? (3D Solid AutoCAD modelling isn't something I'm very familiar with at the moment)
neilyj
11 Kudos
Post 4 of 4
05-22-2013 03:26 AM in reply to: autoMick
In 3D modelling mode, go to the Surface tab, then Convert to NURBS.
However... I couldn't get it work with a box (as the foundation pad). The sphere was picked at random and I assumed it would work with any solid, however, I think the reason it worked was because it had the single outside surface, whereas a box has 6.
I just experimented some more. What you need to do, is get your foundation pad/box and 'convert to surface' which is on 'Mesh' tab. Then do the slice command, using the foundation pad 'surface' to cut away the geology.
Cheers
- Mick
Post to the Community
New Post
