Our roads and aerial images have quit working and are no longer working. All the CAD users in our office are experiencing the same thing.
Any thoughts?
Solved by nicolas.menu. Go to Solution.
Solved by neilyj666. Go to Solution.
Apparently Autodesk does know about the issue and is working to get it fixed.
Glad to see it's not just me. This started yesterday and today it still wasn't working. I did get it to work for about 30 seconds this morning then the image disappeared.
Your Name
What are you getting at?
@Joe-Bouza wrote:
Imagine that? Users having problems with live Map
Like I said this morning, it is working for me.
1. My entities are located in my coordinate system.
2. You need to wait for a few minutes before they show up.
Did you look to see that Autodesk 360 is running in the background?
Bill
Just in case, YES, it is also working now.
What coordinate system are you having success with seeing the Bing map image?
Functionality suspended for the foreseeable future but hopefully not too long......from the Map forum
While we're waiting for a fix, don't forget about Earth Explorer, GloVis, and Landsat Look Viewer:
Dave
Dave Stoll
Las Vegas, Nevada
from Autodesk:
AutoCAD 2014 and 2015 products are experiencing a Bing Maps outage due to a Microsoft security change. The AutoCAD team is working to address this as quickly as possible. Please see the following support article for updates, which will also be visible in product (once available) while using the GeoLocation commands.
DarrenP
Please my Name is James --- I just want to find out if you have resolved the problem (if YES what's the procedure) as I am faced with the same challenge and it is really fustrating. Thanks
