Why do I need to specify my 0,0,0 point when using Geolocation by Map? Can I not bring in Live Maps to an empty drawing and lay my points over it accurately?
Solved by Jay_B. Go to Solution.
Try secifying a coordinate system first and be sure to have an object in the project vicinity in the drawing.
(your points are fine for the object)
Then use the Geomap command & sign into 360 when prompted.
See Murph's post Here for more info.
Now does the Geomap come in correctly?
