neilyj
Message 1 of 2 (259 Views)
Geolocation Aerial Map in wrong place and solution to this
259 Views, 1 Replies
05-14-2013 06:11 AM
I've been working on drawings (originally last year done in Civil 2013 with Geographic locations included) in 2014 and have found that when switching the Map Aerial on the location is very incorrect.:smileyfrustrated::smileyfrustrated:
By using the Remove Location tool and assigning the Coordinate system via the Drawing Properties, the aerial Map is located perfectly...:smileyhappy:
No idea why it does this and haven't tried with other drawings in a different project to the one I'm workling on
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Active Contributor
Kevin.Spear
Message 2 of 2 (225 Views)
Re: Geolocation Aerial Map in wrong place and solution to this
05-14-2013 02:51 PM in reply to: neilyj
Without seeing your drawing, the geolocation was often incorrect in 2013. An indicator was the view cube being in an orientation completely different than the actual orientation.
Kevin
Kevin
Kevin Spear, PE
Synergis Engineering Design Solutions
