Civil 3D Forum
Geolocation Aerial Map in wrong place and solution to this
1 REPLY 1
neilyj666
2500 Views, 1 Reply
I've been working on drawings (originally last year done in Civil 2013 with Geographic locations included) in 2014 and have found that when switching the Map Aerial on the location is very incorrect.Smiley FrustratedSmiley Frustrated
By using the Remove Location tool and assigning the Coordinate system via the Drawing Properties, the aerial Map is located perfectly...Smiley Happy
No idea why it does this and haven't tried with other drawings in a different project to the one I'm workling on
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
1 REPLY 1
Kevin.Spear
in reply to: neilyj666
Without seeing your drawing, the geolocation was often incorrect in 2013. An indicator was the view cube being in an orientation completely different than the actual orientation.
Kevin
Kevin
Kevin Spear, PE
Rail Community
