I searched this topic and found one discussion but not the answer.
I am using a new Geoid and Civil 3D tells me the Geoid model is not found in the Geodata folder.
I can't figure out what folder it's talking about. I don't have a folder named "geodata" on my PC.
Does anyone know where this is suppose to go?
Kevin
If you have the trimble link then it refers to the geodata file in the trimble sync folder. The geodata is used in the Surveyor's data collector to store geoid files and DC files. Normally, I don't use the geoid file through C3D. Instead I handle them through another program specific to my survey instrument (SCS Data Manager). Not sure if any of this will be of use to you.
Normally I import points from a file, but when I try to import a JOB from theTrimble data collector using Trimble Link it looks for the Geoid file.
I don't do it a lot but when I do I have this problem.
the geoid file (downloadable from Trimble Support under Trimble Geomatics Office) is found here: C:\Program Files\Common Files\Trimble\GeoData (C:\Program Files (x86)\Common Files\Trimble\GeoData on a Win7 64-bit machine). You could try to stick it there and see if C3D finds it. Although if you are using a TSC2 (or earlier device), when you installed Trimble Geomatics Office it should have put it there for you. Maybe it is not finding the geoid file named in your coordinate system setup on the data collector?
That's what I needed to know. I tried searching for "geodata" and got no return so I couldn't find the directory.
Thanks a lot!
Kevin
