Civil 3D Forum
Geo Map fix
4 REPLIES 4
AEC_Cadd
1387 Views, 4 Replies
Geo Map fix
How do I fix the Geo Map? I downloaded the fix for C3D 2015, opened a C3D dwg, ran the arx and still the Geo Map will not work. I am running Windows 7, 64 bit so I chose the X64 folder for the arx file. I am logged on to Autodesk 360 so that is working OK. I am in the correct coordinate range for the NAD83 zone for this project. This always worked up until Bing made their changes. I don't know where to go from here. Any help would be greatly appreciated. I saw in the discussion group the it might be a good idea to shut down 360, then start it again. Where do I go to shut it down?
4 REPLIES 4
Pointdump
in reply to: AEC_Cadd
A,
The only thing I can suggest is to update all your Service Packs (important) and follow the Readme step-by-step.
Some Map 3D users are still having problems with Live Maps, possibly network issues.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
AEC_Cadd
in reply to: Pointdump
I do have all the Service Packs installed for C3D and not using Map for this project.
Thanks for your quick input Dave but I need to get this resolved.
Bob
Jeff_M
??? You don't 'run the arx', you must replace the arx file in the install folder with the new one. Did you follow the instructions to the letter?
AEC_Cadd
in reply to: Jeff_M
Thanks for your help, I appreciate it. I thought I just had to load the arx.
Rail Community
