Hi All,
So, we are trying to export GENIO data for the first time using the Civils 3D add-on and for the most part it's exporting all the strings I would expect.
The problem is I have created a sub assembly using the sub assembly creator and while it works perfectly in the Civils 3D model, when I come to export it to GENIO the strings for it do not appear.
Any help would be greatly appreciated.
Solved by TrevN. Go to Solution.
