Any one shed any light on this issue?
I'm building a corridor for a small temporary river diversion from generic links that should be 3m either side with an additional 1m (for erosion protection) to the LHS as shown in the lower image.
I created the assembly but the corridor wasn't building correctly until I altered the 1m link to be 4m as shown in the upper image and the corridor built as expected (lower image) i.e. 4m to the LHS rather than the 7m that the assembly suggests
I'm totally baffled with this and have never had this issue with generic links which I typically use in preference to the prebuilt assemblies. I'm up against it time wise on this so can't take a closer look until next week but at least I have the corridor working as expected.
neilyj (No connection with Autodesk other than using the products in the real world)
I think whats going on is in layout mode the link offset is from the assmebly basepoint; so if you used one meter it thought it was daylighting fron one meter out.
Joe Bouza
This thread may be helpful.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
I think this has always been the case. The Links offset/width value is calcalated from the Baseline so your 4m offset should be 7m hence why the resultant section is drawn as a 1m off of the insertion point. Agreed it's counter intiative, I normally use an offset target to control this so have never really had the issue.
Have you tried to change the offset / width value to 7m so that it is drawn as 4m?
Mark Green
Working on Civil 3D in Canada
