Valued Mentor
engrtech
Message 1 of 5 (269 Views)
Generic Link Slope Problem
269 Views, 4 Replies
12-04-2013 08:06 AM
I haven't had to use a generic link slope in a while, but I'm baffled as to why this isn't working for me. Below is my assembly which looks looks fine, but the corridor is doing the opposite of what it should be doing.
And here is what the corridor is doing.
My grass strip link is going in the opposite direction and it's much longer than 7 feet. Am I missing something or is this another bug?
IDSP 2015
Windows 8.1 Pro 64-bit
8GB RAM
Try using an offset of 27.
Valued Mentor
fcernst
Message 2 of 5 (252 Views)
Re: Generic Link Slope Problem
12-04-2013 10:41 AM in reply to: engrtech
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
Valued Contributor
g_k50
Message 3 of 5 (238 Views)
12-04-2013 11:39 AM in reply to: engrtech
Might need a negative offset on the side that's messing up.
neilyj
Message 4 of 5 (227 Views)
12-04-2013 01:06 PM in reply to: g_k50
It's another non intuitive feature of Civil see here http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Generic-Links-weirdness/td-p/4659095
neilyj
(No connection with Autodesk other than using the products in the real world)
IDSP Premium 2015 (mainly Civil 3D 2015 UKIE & Infraworks with some limited 3ds Max Design)
Win 7 Pro x64, 240Gb SSD, 1Tb HDD
32Gb Ram Intel Xeon CPU E5-2650 v2 @ 2.6GHz (32 CPUs), ~2.6GHz
NVIDIA Quadro K4000, Dual 27" Monitor, Dell T5610
Valued Mentor
engrtech
Message 5 of 5 (218 Views)
12-04-2013 01:58 PM in reply to: fcernst
I had forgot that the offset is relative to baseline and not attachment point. As neilyj said, it's very disconected from what you'd think the behavior would be as the assembly doesn't match what the corridor builds. Autodesk really should fix this.
IDSP 2015
8GB RAM
