Civil 3D Forum
GENERIC LINK ATTACH?
3 REPLIES 3
153 Views, 3 Replies
Working with generic links and trying to insert or attach a link to the LEFT side of the assembly. I'm using linkwidthandslope.
when i try to attach, it appear crossing back over the previous sub-assebly. Then i have to put in negative vaules to make it show correctly. It show in the properties a true of false vaule for left side, but toggling this seems to have no effect. Anyone know how to attach to the LEFT side?
3 REPLIES 3
tcorey
I think you've found the solution. Link objects don't have a side designation like most subassemblies. You use negative values to get them to go left and positive to go right.
Tim Corey
Delta Engineering Systems
Redding, CA
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Only some of the generic links need negative / positive values. The others
have Left / Right properties. he LinWidthandSlope has a Left / Right
property. I'm not sure why the OP is having this problem, I'm not here.
Sounds like maybe a corrupt VBA.
Mat
wrote in message news:5579468@discussion.autodesk.com...
Tim Corey
Redding, CA
Thanks for the replies. I now how Autodesk on the problem, but of course its been two days since i've talked to them on the phone. I sent them the assembly, maybe they crashed!!
Thanks again
Rail Community
