AutoCAD Civil 3D General Discussion
Active Member
tmzcad
Message 1 of 15 (322 Views)
General Target Question
322 Views, 14 Replies
09-25-2012 07:53 AM
I am fairy new to Civil3D, 6 to 8 months, but have extensive knowledge of LDT 15 years. To this date, I still can not figure out why any of my subassemblies do not plot correctly in my sections. I have a brief understanding of the targeting scenerio for assemblies in Civil3D. If I use one of the typical assemblies from Autodesk, I have no problem. My problem is then I try to create my own assembly using the standards sub-assemblies none of the target points look correct.
The attached is an assembly with roadway overlays,curbs, roadside swales and sidewalks with sideslopes.
My basic questions is than, is it Mandatory to select target alignments and surface all every sub-assembly within the assembly.
My thought process was that I just had to pick a profile alignment for the center of the assembly and a target surface for the sideslopes. All the interior sub-assembly parts should float together based on the center profile as they used to with LDT templetes.QLH-ASSEMBLY 1.JPG
*Expert Elite*
tcorey
Message 2 of 15 (311 Views)
Re: General Target Question
09-25-2012 08:35 AM in reply to: tmzcad
No, it's not mandatory to select a target for every subassembly point that allows it. You only do that if your design requires it.
Example, LaneOutsideSuper is a travel lane. In the target parameters of the corridor this subassembly will be listed asking for width and elevation targets. If the width is constant, just set that width in the subassy properties and ignore the targeting info. If, however, the lane needs to transition in width, draw geometry that defines the transition and then specify it here.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
*Expert Elite*
sboon
Message 3 of 15 (301 Views)
09-25-2012 09:10 AM in reply to: tcorey
If you right-click on a subassembly icon in the tool palette and choose the help option it should take you directly to the reference document for that sub.  The help docs for the subassemblies almost always include a section on target parameters.
http://docs.autodesk.com/CIV3D/2012/ENU/filesCSH/GUID-5A0304D4-D167-4156-B9E1-337B8AA7332-55.htm
*Expert Elite*
Jeff_M
Message 4 of 15 (298 Views)
09-25-2012 09:26 AM in reply to: tmzcad
It appears from your image that you are not creating the assmblies correctly. When you add a subassembly, be sure to select the point on the Assembly/previous subassembly to attach the subassembly to. Don't use Objectsnaps, select the point (normally shown as a circle) and then they will be linked as you expect.
Jeff_M, also a frequent Swamper
Active Member
tmzcad
Message 5 of 15 (285 Views)
09-25-2012 10:20 AM in reply to: Jeff_M
Jeff your correct. I have read this suggestion in other messages and have tried clearing the sub-assembly offset and and re-attaching the sub-assembly using the correct points. Still keep getting same result.
As per Steve's suggestion above, reviewing various individual sub-assembly properties it's seems some sub-assemblies do require a mandatory target feature, alignment or profile, or at least in Autodesk help language "you should have" this option when building the assembly. The sub-assembly I may having problem with in this particular assembly is "Urbanreplacmentwalk" which appears to requires an outside alignment for a target.
I was just trying to build a simple assembly that collectively moved in relation to the road's center profile.
Active Member
tmzcad
Message 6 of 15 (277 Views)
09-25-2012 10:58 AM in reply to: sboon
Steve,
Thanks for the repsonse. Also, see my repsonse to Jeff below.
Looking at the image I posted, I have tried attaching the basic "ditch" sub-assembly to the back of the curbs in the sub-assembly. According the ditch sub's help, the connection point should be the beginning of the foreslope if the foreslope buffer is "0", which is what I m using. Now I did not set any targets for this sub-assembly, because I wanted it's position to be controlled by the position of the back of the curb. As you can see by the image, no luck. Any suggestions?
Distinguished Mentor
castled071049
Message 7 of 15 (231 Views)
09-26-2012 09:20 AM in reply to: tmzcad
Give us an image of your assembly, not of a section view of your assembly, please.
Active Member
tmzcad
Message 8 of 15 (222 Views)
09-26-2012 10:52 AM in reply to: castled071049
Per your request. I used a white background so you could see the target points better.QLH-ASSEMBLY 2.JPG
*Expert Elite*
sboon
Message 9 of 15 (207 Views)
09-26-2012 11:42 PM in reply to: tmzcad
Your assembly looks right at first glance.  Can you post the drawing, or at least a portion of it with the assembly.  If its too large for this forum then Dropbox is a good option for sharing files.
Active Member
tmzcad
Message 10 of 15 (197 Views)
09-27-2012 06:29 AM in reply to: sboon
Steve,
If you want to investigate this further, attached is a link to the file, about 18mg. Thanks for any help you can provide.
https://qlha.sharefile.com/d/s566d2656051466e9
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
