Civil 3D Forum
General Note Background mask
23 REPLIES 23
Message 1 of 24
AllenJessup
1560 Views, 23 Replies
Is it a know issue that when you have a General Note style with a Dragged State where the Display is set to Stacked Text. If Background Mask is set to True. The Mask does not encompass the whole text.
Or have I missed something?
Allen Jessup
Civil 3D 2012 SP 2.1
Dell Precision T7400, Xeon CPU 3.16 GHz
Win 7 Pro, 64-bit,12 GB RAM, Nvidia Quadro FX 4600
Allen Jessup
CAD Manager - Designer
23 REPLIES 23
Message 2 of 24
Jay_B
in reply to: AllenJessup
I just tried a general note over two basic lines and it seems to work as expected.
2012 sp 2.1 used.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 24
AllenJessup
in reply to: Jay_B
Interesting. There must be something wrong with my style.
Allen
Allen Jessup
Message 4 of 24
Jeff_M
Change your maximum text width in the Dragged state to either 0 or wider than the text
Message 5 of 24
Jay_B
FWIW, Mine is set to zero. Learned something new.
C3D 2018.1
C3D 2016 SP4
Message 6 of 24
AllenJessup
in reply to: Jeff_M
Thanks Jeff. That was the culprit. I hadn't realized that that would effect the mask also. But it makes sense. Just have to edit a few pieces of text to make them stack the way I want. But little trouble compared to the masking problem. I had to use a couple of wiperouts to get the plots out this afternoon. But now I'll erase them and fix up the notes.
Do you use notes for a lot of labeling? We haven't up until now. But I'm getting tired of the Annotative vs Civil troubles. I can deal with it. But I'm not getting it across to others why some thing do this and other do that. So if we can stick to one method it would be simpler. Unfortunately Notes are still a bit Kludgy.
Allen
Allen Jessup
Message 7 of 24
AllenJessup
in reply to: Jay_B
That's why we're here! Smiley Happy
Allen Jessup
Allen Jessup
Message 8 of 24
Jeff_M
I don't use the General Notes as much as I'd like to. Multileaders seem to do an overall better job at this time, for me anyway. ALthough I do have many notes, that must be on every sheet, for which I've created a style so I can quickly add them.
Message 9 of 24
neilyj666
in reply to: Jeff_M
I tend to use Multi leaders (rightly or wrongly) over Civil Labels as they are much easier to edit etc although Civil Labels do have their uses in the right place e.g. profile views
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 10 of 24
Allen,
I use Civil 3D notes as much as possible due to the way the wipeout ajusts itself to stay wrapped around the text.
although if i need to copy multiple notes to multiple sheets then mtext works  more efficiently.
Message 11 of 24
AllenJessup
Thanks for letting me know. I'll see how they work out for us.
Allen Jessup
Allen Jessup
Message 12 of 24
AllenJessup
I just read this post on copying notes:
Copy General Note Labels between drawings
I haven't tried it yet. But it looks interesting.
The part about renaming the style before copying that is.
Allen Jessup
Allen Jessup
Message 13 of 24
Allen,
The issue is the text overrides to not move from drawing to drawing.   they always take on the text from the style when moved they lose the text override.    I looked at the post link you offered and I don't see anything to help with say 5 note lables that you want to copy to 20 additional sheets.   the best that is doable at this time is to cut and paste the contents of the text override notes one at a time as sinc mentioned.   Or to explode them to mtext, but if you're going to do that you may as well just start with mtext.
thanks for sharing what you thought might be helpful though.
Message 14 of 24
AllenJessup
Thanks Dan. I haven't had time to test it. If something comes of it. I'll let you know.
Allen Jessup
Allen Jessup
Message 15 of 24
AllenJessup
I tested it and renaming the style does let you copy notes from Drawing to Drawing.
Allen
Allen Jessup
Message 16 of 24
I can see how if you make a copy of the style and paste the contents of the edited text into the new style this could now be a label that can be copied into multiple sheets.   But simply renaming the overall style will not save the text override.
another thing i encountered with general notes is not being able to TAB correctly from inside the general note editor.
Please see the attached image where the note on top is the general note label.   the dialogue box is how i entered the information in the text editor.
the note at the bottom is the same note done with mtext.
On a side note I still cannot insert an image into the content of this reply.   a box comes up with options on where to insert a image from but the upload a file button is greyed out.   Autodesk said they fixed it, but I only see a little improvement and not a complete fix.
Message 17 of 24
troma
In answer to your side point, it seems to be working fine here.  I'm in chrome.
Mark Green
Working on Civil 3D in Canada
Message 18 of 24
in reply to: troma
i'm using internet explorer 9.   maybe there is a newer version out there?
Message 19 of 24
AllenJessup
IE 10 is out. I just installed it yesterday. It's a lot faster. I haven't used it enough to get a feel for any problems. None yet anyway.
Allen Jessup
Allen Jessup
Message 20 of 24
Jay_B
Update Version 9.0.14 seems to work ok here.
C3D 2018.1
C3D 2016 SP4
Rail Community
