Civil 3D Forum
General Legal Phrasings . XML
5 REPLIES 5
mikebaldi
1267 Views, 5 Replies
I am using Civil 3D 2012. I am executing the reports General_Legal_Description_for_Alignments and _for_Parcels.
Through some research I was able to figure out where to adjust the precision. I was also able to learn that editing GeneralLegalPhrasings.XML is where I would format the wording.
But, the changes I make to GeneralLegalPhrasings.XML are not being reflected in the reports generated.
For example, Civil 3D defaults a line course to something like this: Thence N DEG MIN SEC E a distance of X.XX feet.
I edited all the mete type = "line" to read as follows: N DEG MIN SEC E, X.XX feet, thence
Here is an example of one of the lines: <Mete type="Point" connect="Line">{lineDirection}, {lineDistanceFoot} feet, thence  </Mete>
They all look like this, except the type and connect values change.
But there is no change in the output.
Thanks in advance for any help.
5 REPLIES 5
stacy.dunn
in reply to: mikebaldi
Where are the files located that you are editing?  The files that C3D uses are located here:
C:\Users\All Users\Autodesk\C3D 2011\enu\Data\Reports\xsl
The ones that the LandXML reporting tool uses are here:
C:\Program Files (x86)\Autodesk\LandXML Reporting 8\Support\xsl
Stacy Dunn
mikebaldi
I am using Win XP so the files are located at: C:\Program Files\Autodesk\LandXML Reporting 7\Support\xsl
I thought I may be editing the wrong file so I searched the entire drive for GeneralLegalPhrasings, legal, .xsl and .xml to find every location these types of files may be, and this was it.
Jeff_M
LandXML Reporting 7 was installed with C3D2009....
For XP you will find C3D2012's reports here:
C:\Documents and Settings\All Users\Application Data\Autodesk\C3D 2012\enu\Data\Reports\xsl
mikebaldi
in reply to: Jeff_M
Thanks Jeff. Is there a reason these files would have been excluded in a search of my C drive?
Jeff_M
I think system/hidden files are excluded from searches without telling Explorer to allow them. But it's been a while since I've used XP on a regular basis, so could be off on that.
Edit - Yep, there's on option on the search panel that you have to specifically tell it to search hidden and system files/folders.
Rail Community
