Good Morning all.
My surface needs to extend just a bit so I traced the outer boundary using
3dpoly and then moved it over 10m. I then add that line using the add
contour under surface definition. Problem is it is leaving a gab between the
contour and the edge of the surface. I try to add lines across the gap and I
get a crossing breakline error.
Problem is under Definition>Breaklines I have no breaklines in this
surface.... so now what.
