I've been trying to fix the contours of a corridor surface taht was handed to me. It's not even a big corridor, just a cul-de-sac. I've resolved many issues so far, but cannot figure out what's causing this. Here is my corridor in the object viewer:
And here is the surface created from that same corridor:
Any reason as to what may be causing this weid gap? I've adjusted the stationing, frequency, verified targets, and rebuilt several times. I've even created a new corridor all together.
Just so you know. . .I've got an alignment going around the bulb of the cul-de-sac where my assembly ties in (ties in at the back of curb). I then target my lane back to the main road centerline alignment. works fine on the top right, but not on the top left.
Any ideas?
Thanks in advance.
It has been a few years, unfortunately, since I have done a cul-de-sac but I seem to remember that it was preferred to run two alignments and meet in the back.
Bill
Infrastructure Suite 2014 Premium SP 1
Thanks! ! Both your suggestions helped in this case. I had to extend the tangents out by about 10 feet like Lisa said, and I created two separate alignments along the bulb, as suggested by WFBerry. That has seemed to resolve this issue.
Thanks again!
