A. ...:
It is a good idea to keep the Pipe Network open. I have a button to just
give me the AutoCAD list command. This command will give me the pipe
number. Use this to see if by chance you have two pipes (numbers) in the
same location, etc. Also look in your Pipe Network in the same alignment
scheme, etc for a "tiny" pipe that got left behind.
Bill
wrote in message news:5035432@discussion.autodesk.com...
Thanks for the reply. I see what you mean about the override, but I'm still
having an issue with the crossing pipes displaying correctly.
I've checked the profile crossing style, but in addition to displaying the
ellipse, I also see the profile pipe lines and can't seem to get them to
turn off with the style override. It appears their may be two pipe objects
atop one another. I can select each object separately and the properties
for each object tells me its the same pipe. However, the profile pipe
network dialog box indicates the pipe is only in the profile once.
Perhaps I'm missing something.
