Civil 3D Forum
future line from object
5 REPLIES 5
nikoue
502 Views, 5 Replies
i try to convert a closed polyline with elevation 0 in feature line. i take a message
" the entire isn't planar to World Coordinate System and can't be converted"
I cant find any problem in polyline. What i can do?
AutoCAD Civil 3D 2013 Hotfix 3.
Win 8 pro x64, OCZ RevoDrive 240GB
Intel i7 930, 12 GB Ram, Ati Firepro V7800
5 REPLIES 5
nicolas.menu
in reply to: nikoue
Hello
This mean the polyline has been created in a UCS, not in WCS.
So, switch back to WCS (command _UCS W), then FLATTEN the polyline...(you will loose Z)
Now you can convert it to a Feature line.
Make sens ?
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Nicolas Menu
Product Support Specialist
Autodesk, Inc.
nikoue
in reply to: nicolas.menu
i created in WCS. But i ve done what tou said and the flatten command does not to have any effect. Only if i choose to remove hidden line but then it change the shape
nikoue
in reply to: nikoue
see the file
nicolas.menu
in reply to: nikoue
Then the fast way...
UCS W , Select the polyline, EXPLODE, PEDIT Join (pick one segment + select all the other with a window selection)
This new PLINE should convert to FL without issue.
Nicolas Menu
Autodesk, Inc.
nikoue
thanks that works. I convert only one line to polyline and joined with the line. Before your answer i had exlode the poly then convert all lines to polys and then joined. that diddnt work
thanks again
Rail Community
